Einleitung
The tools needed are T5 Torx Screwdriver, plastic opening tool, and a soldering iron. In order to take out the motherboard you will need to disconnect the battery and the speaker from it also.
Was du brauchst
Using a T5 Torx screwdriver, remove four 6 mm screws from the four corners of the back of the device.
Grip the device with your hands. Using your thumbs pull the nameplate towards yourself and off the device.
Carefully pull apart the device by opening it up on the opposite side of the nameplate.
Using a soldering iron, desolder the wire connection between the speaker and the device.
Using a T5 Torx Screwdriver, remove the 5mm screws in the four corners of the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
