Einleitung
If your device is not turning on you may need to replace a dead or faulty battery. Use this guide to replace the battery in your Garmin NUVI 2589 by completing the following replacement guide.
Was du brauchst
Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
Using the plastic opening tools, pry the shorter sides of the device apart.
Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
Using the angled tweezers, grip the red, black, and green wires connecting the battery to the motherboard, then gently lift away from the motherboard.
Use the opening tools to gently pry underneath the battery and lift upwards to remove the battery.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Where can I buy this battery
Stan Levin
where can I buy this battery
When pulling off the wires, the plug on the motherboard was coming off. How can I fix it again ?
