Zum Hauptinhalt wechseln
Garmin Nuvi 2589LMT Display Assembly Replacement
Was du brauchst
  1. Garmin Nuvi 2589LMT Display Assembly Replacement, Back Panel Assembly: Schritt 1, Bild 1 von 1
    • Using the T5 Torx Screwdriver, remove all 4 of the 5.7mm screws from the back of the device.
  2. Garmin Nuvi 2589LMT Display Assembly Replacement: Schritt 2, Bild 1 von 2 Garmin Nuvi 2589LMT Display Assembly Replacement: Schritt 2, Bild 2 von 2
    • Using the plastic opening tools, pry the shorter sides of the device apart.
    • Once a gap has formed at the top of the device, insert the opening tool into the gap and slide it along the top of the device. Repeat for the bottom edge of the device to separate the LCD screen from the back.
    • Do not disconnect or tear the ribbon wiring, located at the bottom of the motherboard, when removing the back of the device.
  3. Garmin Nuvi 2589LMT Display Assembly Replacement, Display Assembly: Schritt 3, Bild 1 von 1
    • Using the tweezers, gently pull the ribbon wiring near where it connects to the motherboard to disconnect the ribbon wiring and the display screen from the motherboard.
    • Remove the screen from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Adam Ferraro
920 Reputation
8 Anleitungen geschrieben
USF Tampa, Team 1-2, Nance Fall 2016 Mitglied von USF Tampa, Team 1-2, Nance Fall 2016
USFT-NANCE-F16S1G2
4 Mitglieder
2 Kommentare
Could you please advise where can I find replacement screen for this device
joyarvind - Antwort
I got the ribbon off. There is a plastic piece that flops around that the ribbon was adhered to. Will the replacement ribbon have some type of adhesive on it for installation? Thanks.
Marty Griffin - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 2,403
