Zum Hauptinhalt wechseln
Garmin Nuvi 2595LMT Digitizer Replacement
Was du brauchst
  1. Garmin Nuvi 2595LMT Digitizer Replacement, Garmin Nuvi 2595LMT Back Cover Replacement: Schritt 1, Bild 1 von 1
    • Place the device on the workspace so the screen is facing downward.
  2. Garmin Nuvi 2595LMT Digitizer Replacement: Schritt 2, Bild 1 von 2 Garmin Nuvi 2595LMT Digitizer Replacement: Schritt 2, Bild 2 von 2
    • Using the t5 screwdriver from the iFixit Pro Tool Kit, remove all four 5.6mm screws placing them safely on the table.
  3. Garmin Nuvi 2595LMT Digitizer Replacement: Schritt 3, Bild 1 von 3 Garmin Nuvi 2595LMT Digitizer Replacement: Schritt 3, Bild 2 von 3 Garmin Nuvi 2595LMT Digitizer Replacement: Schritt 3, Bild 3 von 3
    • Grab a spudger from tool kit.
    • Pry open sides of Nuvi gently with spudger (do not rip apart).
    • Use plastic opening tool to pry ribbon slowly from white plastic bar.
    • Separate the two pieces and place them on the table
  4. Garmin Nuvi 2595LMT Digitizer Replacement, Digitizer: Schritt 4, Bild 1 von 2 Garmin Nuvi 2595LMT Digitizer Replacement, Digitizer: Schritt 4, Bild 2 von 2
    • Using the spudger, gently pry the sides of digitizer open until it lifts open and remove the digitizer from the LCD screen.
  5. Garmin Nuvi 2595LMT Digitizer Replacement: Schritt 5, Bild 1 von 1
    • Heat the connection between the digitizer ribbon’s and LCD Screen's ribbon with a hot soldering to separate the two.
    • After the connection is seperated, place the digitizer screen on your work surface.
    • Take the replacement digitizer and place it over the top of the LCD screen.
    • Align the ribbon of the digitizer and lay it over the LCD ribbon.
    • Place the solder underneath the digitizer ribbon and above the LCD ribbon; the area you need to solder is silver and at the bottom of the LCD ribbon.
    • Using the soldering iron, heat up the solder and attach the two ribbons.
    • Let the solder cool for an hour.
    • The soldering iron will be hot. Be careful to not burn yourself.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 1,546
