Zum Hauptinhalt wechseln
Garmin Nuvi 2595LMT LCD Screen Replacement
Was du brauchst
  1. Garmin Nuvi 2595LMT LCD Screen Replacement, Garmin Nuvi 2595LMT Back Cover Replacement: Schritt 1, Bild 1 von 1
    • Place the device on the workspace so the screen is facing downward.
  2. Garmin Nuvi 2595LMT LCD Screen Replacement: Schritt 2, Bild 1 von 2 Garmin Nuvi 2595LMT LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • Using the t5 screwdriver from the iFixit Pro Tool Kit, remove all four 5.6mm screws placing them safely on the table.
  3. Garmin Nuvi 2595LMT LCD Screen Replacement: Schritt 3, Bild 1 von 3 Garmin Nuvi 2595LMT LCD Screen Replacement: Schritt 3, Bild 2 von 3 Garmin Nuvi 2595LMT LCD Screen Replacement: Schritt 3, Bild 3 von 3
    • Grab a spudger from tool kit.
    • Pry open sides of Nuvi gently with spudger (do not rip apart).
    • Use plastic opening tool to pry ribbon slowly from white plastic bar.
    • Separate the two pieces and place them on the table
  4. Garmin Nuvi 2595LMT LCD Screen Replacement, LCD Screen: Schritt 4, Bild 1 von 2 Garmin Nuvi 2595LMT LCD Screen Replacement, LCD Screen: Schritt 4, Bild 2 von 2
    • Grabbing the top half of the Nuvi, remove the screen from the tabs holding it in place using thumbs.
    • Place screen on table.
  5. Garmin Nuvi 2595LMT LCD Screen Replacement: Schritt 5, Bild 1 von 2 Garmin Nuvi 2595LMT LCD Screen Replacement: Schritt 5, Bild 2 von 2
    • Place new screen in proper position, with the ribbon facing downward.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
cannot prise open the connector to replace ribbon
norman bayne - Antwort
My screen is cracked. The screen opens, but I can't use the key board.
Thank You For any Help You Can Give Me,
Cookie
cookiecaafato1@yahoo.com nuvi 2595 LMT
cookiecalafato1 - Antwort
Re-seating the ribbon is simply impossible.
daBee - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 11
Insgesamt: 4,588
