Einleitung
This device can be identified utilizing the criterion on the device page. When replacing the screen, be sure to set aside the following tools: T5 Torx screwdriver and plastic opening tool.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Carefully remove model/serial number sticker.
    • Carefully remove model/serial number sticker.
  2. Remove two 4mm T5 Torx screws located under the sticker.
    • Remove two 4mm T5 Torx screws located under the sticker.
    • Once the screws are removed, use the plastic opening tool to carefully separate the body from the screen encasing.
    • Once the body of the nüvi is separated, carefully flip the tabs on the motherboard that secure the ribbon cable to the motherboard and disconnect.
    • Use a plastic opening tool to loosen the three clips located on the top of the screen encasing to a position that loosens the hold on the screen.
    • Use a plastic opening tool to loosen the two clips on the short sides of the Nuvi screen encasing to a position that allows the removal of the screen.
Abschluss
Hunter Johnson
Mitglied seit 27.03.2018
315 Reputation
2 Anleitungen geschrieben
IUPUI, Team S3-G5, Harley Spring 2018 Mitglied von IUPUI, Team S3-G5, Harley Spring 2018
IUPUI-HARLEY-S18S3G5
3 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 115
