Einleitung
In this guide, we are going to provide step-by-step instructions that will show how to properly replace the device's touch screen.
Was du brauchst
Remove the stand by depressing the tab and rocking the round interface back away from the tab, pulling it away from the Garmin unit.
Remove the four 4mm hex screws from the four corners of the unit using a T5 bit.
Firmly force a plastic spudger into the bottom seam and pry open a section. Use a prying/pushing motion to force the tool into the unit until you feel a click.
Repeat this all the way around the seam.
Do not attempt to separate the unit until all the tabs have been separated. Once the seam is completely separated, you can lift the back away from the screen easily.
Retrieve a new screen and connect the flat-gold wire to the socket from where you removed the old screen.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Were can I order a 6 inch screen for a Garmin Nuvi 2689 LMT
The screws will not come out. I have the screwdriver that was sent with replacement screen. Help!!
