Einleitung
This guide provides step by step instructions for removing and replacing the speaker for your Garmin Nuvi 2689LMT.
Was du brauchst
Begin by removing the stand by depressing the tab and rocking the round interface back toward you, pulling it away from the Garmin unit.
Remove the four, 4mm hex screws at the four corners of the device using a T5 bit.
Firmly force a plastic spudger into the bottom seam and pry open a section. Use a prying/pushing motion to force the spudger into the unit.
Repeat this all the way around the seam.
The white battery is attached to the casing with an adhesive. Separate it with a prying tool.
Remove the four, 4mm hex screws with a T5 bit.
These are located near the four corners of the main circuit board, as shown.
Carefully pick up and remove the main circuit board from the device’s plastic casing.
Remove the speaker - located on the device as shown - from the plastic casing using a prying tool. Use the prying tool around the entire rim of the speaker to ensure a clean removal.
Tape the main circuit board onto a clean surface to steady the device.
Retrieve your replacement speaker and re-solder the wires back onto the main circuit board.
2 Kommentare
Hi what's the make and model of the replacement speaker for the nuvi 2689 model. Where can I find that particular part.
