Zum Hauptinhalt wechseln
Garmin Nuvi 2797LMT LCD Screen Replacement
Was du brauchst
  1. Garmin Nuvi 2797LMT LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 1
    • Before you begin make sure your device is turned off.
    • Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
  2. Garmin Nuvi 2797LMT LCD Screen Replacement: Schritt 2, Bild 1 von 3 Garmin Nuvi 2797LMT LCD Screen Replacement: Schritt 2, Bild 2 von 3 Garmin Nuvi 2797LMT LCD Screen Replacement: Schritt 2, Bild 3 von 3
    • Using the biggest plastic opening tool, pry open the GPS from the sides. You should now be able to see everything inside the GPS.
    • Be careful when opening the GPS because of the ribbon attached to the screen. It can tear easily.
  3. Garmin Nuvi 2797LMT LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Locate the ribbon attached to the motherboard. Carefully detach the ribbon.
  4. Garmin Nuvi 2797LMT LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Using your T-4 Torx Screwdriver, unscrew the four 2.38 mm Torx T-4 screws from the back of your screen.
  5. Garmin Nuvi 2797LMT LCD Screen Replacement: Schritt 5, Bild 1 von 2 Garmin Nuvi 2797LMT LCD Screen Replacement: Schritt 5, Bild 2 von 2
    • Now pulling up on one of the corners, bring the top half of the casing out of the bottom half.
  6. Garmin Nuvi 2797LMT LCD Screen Replacement: Schritt 6, Bild 1 von 2 Garmin Nuvi 2797LMT LCD Screen Replacement: Schritt 6, Bild 2 von 2
    • Now remove the front casing and back casing away from the screen. You will end up with three separate pieces.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
baileykaytar
366 Reputation
2 Anleitungen geschrieben
Sam Houston State, Team 2-6, Blackburne Fall 2015 Mitglied von Sam Houston State, Team 2-6, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S2G6
3 Mitglieder
4 Anleitungen geschrieben
2 Kommentare
Instructions lacking. Go here, https://www.youtube.com/watch?v=iMotyMvC... . Not the exact same Garmin, but virtually the same and worked much better than the instructions here!!
allen1 - Antwort
Still can't get my older Garmin back in working order.
where can i take it for someone else to re-cycle it as I have a brand new one .
Thomas L Camp - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 2,303
