Einleitung
Here are a few easy steps on how to correctly remove the motherboard so a new one can be installed.
Ersatzteile
Kein Ersatzteil erforderlich.
Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
Using the biggest plastic opening tool, pry open the GPS from the sides. You should now be able to see everything inside the GPS.
With the device opened, carefully remove the ribbon from the motherboard.
Unplug the three wire connectors from the motherboard.
Using your T-4 Torx Screwdriver, unscrew six 1.58 mm T-4 Torx screws from the motherboard.
Now remove the motherboard out of the device. You will have two separate pieces.
Ein weiterer Nutzer hat diese Anleitung absolviert.
Ein Kommentar
Do you know if there is any point on the motherboard where you could attach an external antenna? Or is the internal antenna removable to be replaced with an external or hacked to connect via a cable run to the outside of the device?
Did you happen to take a picture of the underside of the motherboard?
Thanks!
