Einleitung
This guide will teach you step by step how to replace your speaker.
Was du brauchst
Using your T-6 Torx Screwdriver, unscrew the ten 2.38 mm torx T-6 screws from the back of your GPS.
Using the biggest plastic opening tool, pry open the GPS from the sides. You should now be able to see everything inside the GPS.
Locate the speaker's wire connector plugged into the motherboard. Now delicately detach the speaker connector by pulling directly up.
Now using the nylon or metal spudger, carefully pry the glue away from the sides of the speaker.
Now using the plastic opening tool, pry the speaker up from one of the sides. Your speaker will completely come out of the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
