Einleitung
In this guide the repairer replaces the auxiliary audio out port of the device by disassembling to expose the motherboard and desoldering the component.
Prerequisite Guide:
Disassembling Garmin Nuvi 370 Into Core Components
Tools Used:
- Fine Point Tweezers
- Spudger
- Soldering Iron
- Solder Extraction Tool
- Copper Braid
- Solder Sucker
Estimated Duration: 15 minutes
Was du brauchst
After following the instructions in the main dis-assembly guide, you should have the screen detached from the motherboard.
The motherboard will now freely separate from the back casing; lay it flat next to the housing.
Disconnect the speaker and battery from their terminals on the motherboard. This should disconnect the motherboard completely from the back panel.
In diesem Schritt verwendetes Werkzeug:Desoldering Pump$3.99
De-solder the audio out port. Use a soldering iron to melt the solder on each of the leads of the port and a solder extraction tool (not shown), such as a solder sucker or copper braid.
The audio out port should now be completely separated from all other components.
Solder new, functional audio port. Make sure all solder connections are clean.
