Zum Hauptinhalt wechseln
Garmin Nuvi 42LM Battery Replacement
Was du brauchst
  1. Garmin Nuvi 42LM Battery Replacement, Battery: Schritt 1, Bild 1 von 3 Garmin Nuvi 42LM Battery Replacement, Battery: Schritt 1, Bild 2 von 3 Garmin Nuvi 42LM Battery Replacement, Battery: Schritt 1, Bild 3 von 3
    • Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
  2. Garmin Nuvi 42LM Battery Replacement: Schritt 2, Bild 1 von 3 Garmin Nuvi 42LM Battery Replacement: Schritt 2, Bild 2 von 3 Garmin Nuvi 42LM Battery Replacement: Schritt 2, Bild 3 von 3
    • Pry the GPS open using a plastic opening tool.
    • When prying open the device, use caution to avoid damaging the motherboard.
  3. Garmin Nuvi 42LM Battery Replacement: Schritt 3, Bild 1 von 3 Garmin Nuvi 42LM Battery Replacement: Schritt 3, Bild 2 von 3 Garmin Nuvi 42LM Battery Replacement: Schritt 3, Bild 3 von 3
    • Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
    • There are two screws - one in the back and one in the front.
  4. Garmin Nuvi 42LM Battery Replacement: Schritt 4, Bild 1 von 1
    • Move the motherboard from from its designated location on the GPS.
    • Do not pull on red, green, and black cables when repositioning the motherboard.
  5. Garmin Nuvi 42LM Battery Replacement: Schritt 5, Bild 1 von 2 Garmin Nuvi 42LM Battery Replacement: Schritt 5, Bild 2 von 2
    • Gently unplug the red, green, and black bundled cable to remove the battery.
  6. Garmin Nuvi 42LM Battery Replacement: Schritt 6, Bild 1 von 2 Garmin Nuvi 42LM Battery Replacement: Schritt 6, Bild 2 von 2
    • Use blue plastic opening tool to carefully pry the battery from the GPS.
    • You might need to use additional force when prying because there is adhesive glue on the back of the battery.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
on my Nuvi 55-diconnected ribbon cable by accident. When I reconnect I get a white screen. How to get the terminals to line up correctly?
Mike - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 17
Insgesamt: 1,291
