Einleitung
Before replacing the battery, visit this device's troubleshooting page to determine whether you need to replace the battery. Follow the steps in this guide if you need to replace the battery.
Was du brauchst
Remove the four screws on the back of the GPS using the T5 Torx screwdriver.
Using the T5 Torx screwdriver, remove the two screws located on the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
