Zum Hauptinhalt wechseln
Garmin Nuvi 50LM Power Button Replacement
Was du brauchst
  1. Garmin Nuvi 50LM Power Button Replacement, Power Button Replacement: Schritt 1, Bild 1 von 2 Garmin Nuvi 50LM Power Button Replacement, Power Button Replacement: Schritt 1, Bild 2 von 2
    • Use the T-4 screwdriver to unscrew the 9 mm screws on the back of the device.
  2. Garmin Nuvi 50LM Power Button Replacement: Schritt 2, Bild 1 von 2 Garmin Nuvi 50LM Power Button Replacement: Schritt 2, Bild 2 von 2
    • Pry open the device from all four sides using the iFixit Plastic Opening Tool until you see the inside of the system.
  3. Garmin Nuvi 50LM Power Button Replacement: Schritt 3, Bild 1 von 2 Garmin Nuvi 50LM Power Button Replacement: Schritt 3, Bild 2 von 2
    • Look for a small button on the motherboard at the top of the device, and insert replacement power button on top of the small button on the motherboard until you hear a click.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Sam Houston State, Team 2-7, Blackburne Fall 2015 Mitglied von Sam Houston State, Team 2-7, Blackburne Fall 2015
SHSU-BLACKBURNE-F15S2G7
4 Mitglieder
5 Anleitungen geschrieben
3 Kommentare
Does not help me a bit. My button fell off and I did not see it come off, so it is lost. Cannot fix it without info of where to get a replacement!
Denny Manning - Antwort
The power button on my Garmin 50 LM fell off the other day. I can’t find anywhere where I can buy a new replacement. Any suggestions would be much appreciated. Thank you!
Mary - Antwort
I’m looking for same switch part for nuvi 40lm. Unless we purchase a whole
Unit from EBay that doesn’t work just for the switch. Good luck if you find one.
Erik Pistek - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 33
Insgesamt: 6,808
