Zum Hauptinhalt wechseln
Garmin Nuvi 56LMT Battery Replacement
Was du brauchst
  1. Garmin Nuvi 56LMT Battery Replacement, Battery: Schritt 1, Bild 1 von 2 Garmin Nuvi 56LMT Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Before disassembling, power off the device.
    • There are four 11.0 mm screws located at each corner on the back of the device.
    • With the T5 torx screwdriver, remove these screws and set aside in a safe place.
  2. Garmin Nuvi 56LMT Battery Replacement: Schritt 2, Bild 1 von 3 Garmin Nuvi 56LMT Battery Replacement: Schritt 2, Bild 2 von 3 Garmin Nuvi 56LMT Battery Replacement: Schritt 2, Bild 3 von 3
    • Using the plastic opening tool, pry apart the device around the seam.
  3. Garmin Nuvi 56LMT Battery Replacement: Schritt 3, Bild 1 von 3 Garmin Nuvi 56LMT Battery Replacement: Schritt 3, Bild 2 von 3 Garmin Nuvi 56LMT Battery Replacement: Schritt 3, Bild 3 von 3
    • Observe the ribbon connecting the screen to the circuit board.
    • Detach the clip using the plastic opening tool and set aside the screen.
  4. Garmin Nuvi 56LMT Battery Replacement: Schritt 4, Bild 1 von 3 Garmin Nuvi 56LMT Battery Replacement: Schritt 4, Bild 2 von 3 Garmin Nuvi 56LMT Battery Replacement: Schritt 4, Bild 3 von 3
    • Using the T5 Torx screwdriver, remove the two remaining 5.0 mm screws.
    • Lift the board from its housing and then detach the plug coming from the battery.
  5. Garmin Nuvi 56LMT Battery Replacement: Schritt 5, Bild 1 von 1
    • If the battery is glued in place use the plastic opening tool to remove it.
    • Finally, exchange the old battery with the replacement.
Abschluss
USF Tampa, Team S3-G5, Nance Fall 2017 Mitglied von USF Tampa, Team S3-G5, Nance Fall 2017
USFT-NANCE-F17S3G5
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 416
