Einleitung
This guide will show you how to replace the display screen on your Garmin Nuvi 56lmt.
Was du brauchst
Locate the four 11.0 mm Torx screws and remove them with the T5 Torx screwdriver.
Run the plastic opening tool around the border of the device until it can be easily pried open by hand.
With your fingers hold back each of the clips located around the border of the screens back.
Pull screen up and slide out in the opposite direction of the ribbon to avoid snapping the fixed clips.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
