Zum Hauptinhalt wechseln
Garmin Nuvi 56LMT Motherboard Replacement
Was du brauchst
  1. Garmin Nuvi 56LMT Motherboard Replacement, Motherboard: Schritt 1, Bild 1 von 1
    • Power off the Garmin Nuvi 56LMT before disassembling.
    • This will teach you how to replace the motherboard of the Garmin Nuvi 56LMT
  2. Garmin Nuvi 56LMT Motherboard Replacement: Schritt 2, Bild 1 von 3 Garmin Nuvi 56LMT Motherboard Replacement: Schritt 2, Bild 2 von 3 Garmin Nuvi 56LMT Motherboard Replacement: Schritt 2, Bild 3 von 3
    • Remove the 11mm screws on the back side of the case with a T5 torx screwdriver.
    • Then, use the plastic opening tool to carefully pry the case open.
  3. Garmin Nuvi 56LMT Motherboard Replacement: Schritt 3, Bild 1 von 3 Garmin Nuvi 56LMT Motherboard Replacement: Schritt 3, Bild 2 von 3 Garmin Nuvi 56LMT Motherboard Replacement: Schritt 3, Bild 3 von 3
    • Use the plastic opening tool to carefully pry the battery from the case.
    • Then remove the 5mm screws that are present on the motherboard.
    • Disconnect the battery from the motherboard, by pinching the wires and pulling straight out.
  4. Garmin Nuvi 56LMT Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the ribbon connecting the motherboard to the screen by using the wedge to peel back the clasp holding the ribbon in place.
  5. Garmin Nuvi 56LMT Motherboard Replacement: Schritt 5, Bild 1 von 1
    • The speaker is soldered to the motherboard so they need to be removed together. Use the plastic opening tool to remove the speaker from the case.
Abschluss
Ryan Bliss
101 Reputation
1 Anleitung geschrieben
USF Tampa, Team S3-G5, Nance Fall 2017 Mitglied von USF Tampa, Team S3-G5, Nance Fall 2017
USFT-NANCE-F17S3G5
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 3
Letzte 30 Tage: 8
Insgesamt: 291
