Zum Hauptinhalt wechseln
Garmin Nuvi 65LM Car Charger Fuse Replacement
Was du brauchst
  1. Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: Schritt 1, Bild 1 von 3 Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: Schritt 1, Bild 2 von 3 Garmin Nuvi 65LM Car Charger Fuse Replacement, Car Charger Fuse: Schritt 1, Bild 3 von 3
    • Hold the car charger with your hands so the metal tip is facing towards you.
    • Insert the flat end of the spudger into the slotted grove of the black plastic surrounding the metal tip by pressing down on the tip.
    • Simultaneously press down and turn the spudger counter-clockwise 90 degrees to unlock the black plastic cap.
  2. Garmin Nuvi 65LM Car Charger Fuse Replacement: Schritt 2, Bild 1 von 3 Garmin Nuvi 65LM Car Charger Fuse Replacement: Schritt 2, Bild 2 von 3 Garmin Nuvi 65LM Car Charger Fuse Replacement: Schritt 2, Bild 3 von 3
    • Carefully take off the black plastic cap surrounding the charging tip with your hands.
    • Use your hands to pull off the silver metal tip away from the charger.
  3. Garmin Nuvi 65LM Car Charger Fuse Replacement: Schritt 3, Bild 1 von 1
    • Turn the charger compartment over and carefully dump the fuse into your hand.
Abschluss
Kai Ling Liang
246 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 15-3, Amido Spring 2015 Mitglied von Cal Poly, Team 15-3, Amido Spring 2015
CPSU-AMIDO-S15S15G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 10
Insgesamt: 2,077
