Einleitung
If you need to replace the silicon buttons in a Garmin STRIKER 4, access them with this guide. Some reasons you may be replacing the buttons include the button pegs being worn down.
Was du brauchst
Remove all six 6 mm screws using a Phillips #0 screwdriver.
Detach and flip the backside to open the device.
Slide out the screen cable from the motherboard using the iFixit opening tool or your fingernail.
Remove the motherboard from the device.
Use the iFixit opening tool to lift the silicon buttons from their original casing.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
