Einleitung
This guide will help you replace the outer casing of your Garmin StreetPilot C330.
Was du brauchst
At the top of the outer frame, insert the plastic spudger into the groove in the center.
Lever the frame gently until it pops out of the case.
Gently pull from both ends of the casing to separate the front and back panels.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
