Einleitung
For this guide you will be opening the device, but it is fairly simple. Before you begin disassembling the device, be sure the power is off.
Was du brauchst
Wedge a plastic opening tool in between the outer frame and the rear panel assembly.
Pry the outer frame off the perimeter of the rear panel assembly.
Remove the four #00 Phillips screws securing the front case assembly to the rear case assembly.
Carefully lift, but do not completely separate, the front case assembly from the rear case assembly.
Gently pull the battery cable connector from its socket on the motherboard.
The second connector can remain attached to the motherboard, but be careful not to break the connector while handling both halves of the device.
Remove the two Phillips #00 screws securing the motherboard to the front case assembly.
Use the edge of a plastic opening tool to flip up the retaining flap on the LCD ribbon cable ZIF socket.
Use the plastic opening tool to pull the LCD ribbon cable out of its socket.
Disconnect the right connector using the edge of a plastic opening tool.
1 Kommentar zur Anleitung
Geometry Dash World delivers short levels that are full of speed and excitement. Every jump must be timed carefully to avoid failure. The vibrant graphics and electronic music make the gameplay feel alive. It’s addictive from the very first level.
