Zum Hauptinhalt wechseln
Garmin StreetPilot c330 Speakers Replacement
Was du brauchst
  1. Garmin StreetPilot c330 Speakers Replacement, Outer Casing: Schritt 1, Bild 1 von 3 Garmin StreetPilot c330 Speakers Replacement, Outer Casing: Schritt 1, Bild 2 von 3 Garmin StreetPilot c330 Speakers Replacement, Outer Casing: Schritt 1, Bild 3 von 3
    • At the top of the outer frame, insert the plastic spudger into the groove in the center.
    • Lever the frame gently until it pops out of the case.
  2. Garmin StreetPilot c330 Speakers Replacement: Schritt 2, Bild 1 von 3 Garmin StreetPilot c330 Speakers Replacement: Schritt 2, Bild 2 von 3 Garmin StreetPilot c330 Speakers Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the four screws around the screen.
  3. Garmin StreetPilot c330 Speakers Replacement: Schritt 3, Bild 1 von 2 Garmin StreetPilot c330 Speakers Replacement: Schritt 3, Bild 2 von 2
    • Gently pull from both ends of the casing to separate the front and back panels.
    • Do not force the pieces apart wider than the length of the connecting wires, or you will damage the wiring.
  4. Garmin StreetPilot c330 Speakers Replacement: Schritt 4, Bild 1 von 3 Garmin StreetPilot c330 Speakers Replacement: Schritt 4, Bild 2 von 3 Garmin StreetPilot c330 Speakers Replacement: Schritt 4, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Gently unplug the white cable connector using either your fingers or tweezers.
  5. Garmin StreetPilot c330 Speakers Replacement: Schritt 5, Bild 1 von 1
    • Carefully expose both halves of the device.
    • Be sure not to pull the two halves apart further than the black wire can reach.
  6. Garmin StreetPilot c330 Speakers Replacement, Battery: Schritt 6, Bild 1 von 3 Garmin StreetPilot c330 Speakers Replacement, Battery: Schritt 6, Bild 2 von 3 Garmin StreetPilot c330 Speakers Replacement, Battery: Schritt 6, Bild 3 von 3
    • Use a Phillips #00 screwdriver to remove the two screws from the battery bracket.
  7. Garmin StreetPilot c330 Speakers Replacement: Schritt 7, Bild 1 von 3 Garmin StreetPilot c330 Speakers Replacement: Schritt 7, Bild 2 von 3 Garmin StreetPilot c330 Speakers Replacement: Schritt 7, Bild 3 von 3
    • Carefully peel the metal bracket away from the battery.
    • Pull the battery away from the back cover.
    • Desolder the wires from the speakers using a soldering iron.
  8. Garmin StreetPilot c330 Speakers Replacement, Speakers: Schritt 8, Bild 1 von 2 Garmin StreetPilot c330 Speakers Replacement, Speakers: Schritt 8, Bild 2 von 2
    • Carefully use the spudger to pry the speakers from the outer casing.
    • Once removed, you may use a soldering iron to remove the wires from the speakers.
Abschluss
Cal Poly, Team 22-1, Maness Fall 2010 Mitglied von Cal Poly, Team 22-1, Maness Fall 2010
CPSU-MANESS-F10S22G1
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 40
Insgesamt: 1,927
