Einleitung
This guide uses the iOpener and black spudger to remove the broken screen from the device, allowing for replacement. Screen replacement will compromise waterproof integrity.
Was du brauchst
Apply the Heated iOpener to the display for 30 seconds to soften the adhesive..
Insert a spudger between the display and watch body.
Pry upwards and work the spudger around the perimeter of the display to free it from the body.
Lift the touchscreen to expose ribbon cables that connect it to the main circuit board.
Use the flat end of a spudger to disconnect the display cable press connectors from the motherboard.
16 weitere Nutzer:innen haben diese Anleitung absolviert.
19 Kommentare
Hello,
thanks for this. Where can i buy the new screen?
Nice guide! Thanks. But I can’t find any parts to repair my watch
What type of glue i use to connect the display an the body?
I’ve only found a couple sources for the adhesive.
