Was du brauchst
Lift the handle and turn it counter clockwise.
Use a TR6 screwdriver to remove all six 11 mm case screws.
Remove the battery housing.
Use a T4 screwdriver to remove the single 5 mm screw that secures the motherboard.
Using a plastic pry bar lift up on the indicated area.
Use thumbs to pull apart joystick
Fast fertig!
Abschluss
