Einleitung
The Garmin fenix 6X Sapphire is a fitness watch identified by Garmin as part numbers 010-02157-10, 010-02158-10, and 010-02159-10, depending on the size of the case. The watch band holds the watch to your wrist. If your watch band has snapped or is torn, this guide will help you replace it.
No tools are needed for this guide, but the tab used to remove the watch can be difficult to pull, so a spudger or jimmy can be useful in place of your finger.
Was du brauchst
Grip one side of the watch band and pull the tab on the band away from the watch face.
Pull the band away from the watch face while continuing to press the tab.
Repeat for the band on the other side.
