Einleitung
This guide demonstrates how to replace the nylon strap of the Garmin inReach Mini. Removing the nylon strap is the first step before removing the back hard case, in the event that the battery or motherboard needs replacement. The nylon strap does not impact the functionality of the device and is otherwise unlikely to need a replacement.
Was du brauchst
Place the device on a level surface with the back hard case facing up.
Use the T5 to remove the 1.9mm screw attached to the nylon strap.
Remove the nylon strap.
