Einleitung
Remove that battery to avoid electrocution. The light sensor is delicate, so be cautious when removing it.
Was du brauchst
Turn the device off by pressing and holding the power button on the top left of the device.
Use the plastic opening tool to separate the tabs on the black back cover of the device by leveraging the tool against the frame around the perimeter of the device.
Using the plastic spudger, carefully remove the white tab connected to the battery from the device by pulling the tab in the opposite direction from which it is connected.
Using the T5 bit, unscrew the four 5.7mm screws in the four corners of the device.
Leverage the plastic opening tool to pop the tabs between the black screen and the metal frame around the perimeter of the device.
Locate the red and black wire connected to the circuit board with the round, black, rubbery disc that was connected to the other half of the device (that disc is the light sensor). Gently pull the wire up from the circuit board.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
