Einleitung
This guide will be helpful if you are attempting to replace your nuviCam LMTHD battery. You might have a little trouble opening the device, but it does come off with a little force using the plastic prying tools. You might need to replace the battery if your device is not holding it's charge or the device is over heating. The battery is fairly simple to remove, good luck.
Was du brauchst
Pry the device open using a plastic opening tool.
We suggest starting from the dash camera side for easier opening
Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
Disconnect battery from device pulling the green, red, and black wires from motherboard.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Disconnect orange cable strip laying across battery by sliding it out of connector .
7 weitere Personen haben diese Anleitung absolviert.
4 Kommentare
Where did you buy the battery? What is the voltage/current?
I believe Garmin Part No. 361-00066-00 is correct (also used in the Nuvi 27xx series). It is available on AMazon and eBay.
