Zum Hauptinhalt wechseln
Garmin nuviCam LMTHD Dash Camera Replacement
Was du brauchst
  1. Garmin nuviCam LMTHD Dash Camera Replacement, Screen: Schritt 1, Bild 1 von 2 Garmin nuviCam LMTHD Dash Camera Replacement, Screen: Schritt 1, Bild 2 von 2
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Dash Camera Replacement: Schritt 2, Bild 1 von 2 Garmin nuviCam LMTHD Dash Camera Replacement: Schritt 2, Bild 2 von 2
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Dash Camera Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Dash Camera Replacement: Schritt 4, Bild 1 von 2 Garmin nuviCam LMTHD Dash Camera Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Dash Camera Replacement, Dash Camera: Schritt 5, Bild 1 von 2 Garmin nuviCam LMTHD Dash Camera Replacement, Dash Camera: Schritt 5, Bild 2 von 2
    • Remove green strip of tape over orange strip.
    • Disconnect orange strip from device using plastic opening tools.
  6. Garmin nuviCam LMTHD Dash Camera Replacement: Schritt 6, Bild 1 von 2 Garmin nuviCam LMTHD Dash Camera Replacement: Schritt 6, Bild 2 von 2
    • Unscrew six 5.74mm silver screws using the T4 screw bit.
  7. Garmin nuviCam LMTHD Dash Camera Replacement: Schritt 7, Bild 1 von 3 Garmin nuviCam LMTHD Dash Camera Replacement: Schritt 7, Bild 2 von 3 Garmin nuviCam LMTHD Dash Camera Replacement: Schritt 7, Bild 3 von 3
    • Pop out green plate using plastic prying tool.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 434
