Zum Hauptinhalt wechseln
Garmin nuviCam LMTHD Motherboard Replacement
Was du brauchst
  1. Garmin nuviCam LMTHD Motherboard Replacement, Screen: Schritt 1, Bild 1 von 2 Garmin nuviCam LMTHD Motherboard Replacement, Screen: Schritt 1, Bild 2 von 2
    • Remove the four 6.9 mm black screws using the T6 screw bit.
  2. Garmin nuviCam LMTHD Motherboard Replacement: Schritt 2, Bild 1 von 2 Garmin nuviCam LMTHD Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Pry the device open using a plastic opening tool.
    • We suggest starting from the dash camera side for easier opening
    • You may have to use a little force, the screen is hard to remove.
  3. Garmin nuviCam LMTHD Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Disconnect the black and red wire from the screen.
  4. Garmin nuviCam LMTHD Motherboard Replacement: Schritt 4, Bild 1 von 2 Garmin nuviCam LMTHD Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Disconnect the orange strip by flipping up the connector with a plastic opening tool and sliding the cable out.
  5. Garmin nuviCam LMTHD Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 1
    • Disconnect battery wire from motherboard.
  6. Garmin nuviCam LMTHD Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Disconnect yellow ribbon cable from motherboard.
  7. Garmin nuviCam LMTHD Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Pull off black and red wire from screen.
  8. Garmin nuviCam LMTHD Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Disconnect the orange cable strip connected to the screen using a plastic opening tool, lift white teeth up and slide strip out.
  9. Garmin nuviCam LMTHD Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove silver plate from motherboard.
  10. Garmin nuviCam LMTHD Motherboard Replacement: Schritt 10, Bild 1 von 2 Garmin nuviCam LMTHD Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Remove all six 5.74mm screws from motherboard using the T4 screw bit.
  11. Garmin nuviCam LMTHD Motherboard Replacement: Schritt 11, Bild 1 von 2 Garmin nuviCam LMTHD Motherboard Replacement: Schritt 11, Bild 2 von 2
    • Lift motherboard out of device using plastic opening tools.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Where to buy the replacement mother board? I couldn't find one.
BTW: Nicely done guide.
pitt83 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 656
