Zum Hauptinhalt wechseln
Gateway 3545GZ Fan Replacement
Was du brauchst
  1. Gateway 3545GZ Fan Replacement, Fan: Schritt 1, Bild 1 von 2 Gateway 3545GZ Fan Replacement, Fan: Schritt 1, Bild 2 von 2
    • Unscrew 14mm screws with Phillips screwdriver.
    • Unscrew 3mm screws with the same Phillips screwdriver.
    • Screws that are circled in red are 3mm; the screw circled in blue is 14mm
    • Remove the protective cover.
  2. Gateway 3545GZ Fan Replacement: Schritt 2, Bild 1 von 3 Gateway 3545GZ Fan Replacement: Schritt 2, Bild 2 von 3 Gateway 3545GZ Fan Replacement: Schritt 2, Bild 3 von 3
    • Unscrew the four screws holding it in place with the same PH1 Phillips-Head screwdriver. They are numbered on the fan, 1,2,3,4.
    • The four screws are 12mm long, they also have a spring surrounding them.
    • Then carefully pull the cord connecting the fan to the notebook.
    • Insert your replacement fan, plug in its cord, screw it into place, and reattach the protective cover.
Abschluss
Nathan Parr
25 Reputation
3 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 216
