Einleitung
This guide is for replacing the hard drive of this specific laptop model. If you have not already checked the device page on troubleshooting, it is advised that you do so before beginning this guide. A PH1 Phillips-Head screwdriver is required to complete this guide.
Was du brauchst
Flip the laptop so that the bottom is facing you. You will find in the lower left-hand corner a hole with a small screw; unscrew this with a PH1 Phillips-head screwdriver (Has a plus shape).
Screw Length: 3mm
Finally, slide the hard drive out of its dock; then just lift the hard drive out of the pocket.
