Zum Hauptinhalt wechseln
Gateway 3545GZ Internet Card Replacement
Was du brauchst
  1. Gateway 3545GZ Internet Card Replacement, Internet Card: Schritt 1, Bild 1 von 1
    • Flip your laptop over and locate the sticker indicating where the internet card is.
    • Using a PH1 Phillips-Head screwdriver, carefully unscrew the screw holding the flap down
    • The screw length is 3mm
  2. Gateway 3545GZ Internet Card Replacement: Schritt 2, Bild 1 von 1
    • Carefully remove the flap over the internet card.
  3. Gateway 3545GZ Internet Card Replacement: Schritt 3, Bild 1 von 2 Gateway 3545GZ Internet Card Replacement: Schritt 3, Bild 2 von 2
    • Unhook the two cords attached to the internet card and remove the card.
    • Next, pull the two metal hooks holding the card in place away from each other.
    • The card should pop out and just take it out from the dock.
Abschluss
Baylee Harding
25 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 6
Insgesamt: 287
