Zum Hauptinhalt wechseln
Gateway 600YG2 LCD Replacement
Was du brauchst
  1. Gateway 600YG2 LCD Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop over.
    • Slide the battery release tab to the right with your index finger to open the battery cover.
  2. Gateway 600YG2 LCD Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery cover using the tab on the right side.
    • Take the battery out with your index finger.
  3. Gateway 600YG2 LCD Replacement, Power Button Panel: Schritt 3, Bild 1 von 1
    • Insert the spudger between the "sysrq" and "ins" keys.
    • Gently pry free the power button panel above the keyboard, beginning from the right and moving to the left.
  4. Gateway 600YG2 LCD Replacement, LCD: Schritt 4, Bild 1 von 1
    • Remove the five screws with a Phillips #0 screwdriver.
    • The LCD hinge covers are held in place by four screws. One screw is for grounding the LCD.
    • Lift the hinge covers along the outer edges with the spudger until they are released.
  5. Gateway 600YG2 LCD Replacement: Schritt 5, Bild 1 von 1
    • Gently unplug the LCD from the system board.
  6. Gateway 600YG2 LCD Replacement: Schritt 6, Bild 1 von 1
    • Using the Phillips #0 screwdriver, remove six screws that hold the LCD to the hinge.
  7. Gateway 600YG2 LCD Replacement: Schritt 7, Bild 1 von 1
    • Check if any cables are still connected before pulling out the LCD.
    • Remove the cable by gently pulling it out while holding down the LCD.
Abschluss
Cal Poly, Team 20-10, Maness Fall 2010 Mitglied von Cal Poly, Team 20-10, Maness Fall 2010
CPSU-MANESS-F10S20G10
3 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 1,873
