Zum Hauptinhalt wechseln
Gateway GWTC116-2BL Display Replacement
Was du brauchst
  1. Gateway GWTC116-2BL Display Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Ground yourself before disassembling and handling the computer.
    • Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
  2. Gateway GWTC116-2BL Display Replacement: Schritt 2, Bild 1 von 2 Gateway GWTC116-2BL Display Replacement: Schritt 2, Bild 2 von 2
    • Use the spudger to pry the back panel away from the body of the laptop.
  3. Gateway GWTC116-2BL Display Replacement, Battery: Schritt 3, Bild 1 von 1
    • Remove the five 3.0 mm Phillips #00 screws.
  4. Gateway GWTC116-2BL Display Replacement: Schritt 4, Bild 1 von 2 Gateway GWTC116-2BL Display Replacement: Schritt 4, Bild 2 von 2
    • Using your fingers, flick open the battery connector bracket.
    • Remove the connector from bracket.
  5. Gateway GWTC116-2BL Display Replacement: Schritt 5, Bild 1 von 1
    • Pull up the battery to remove from the base.
  6. Gateway GWTC116-2BL Display Replacement, Motherboard: Schritt 6, Bild 1 von 1
    • Using your fingers, flick the cable connector bracket open.
    • Remove the cable from the connector.
  7. Gateway GWTC116-2BL Display Replacement: Schritt 7, Bild 1 von 2 Gateway GWTC116-2BL Display Replacement: Schritt 7, Bild 2 von 2
    • Using your fingers, disconnect the black and white connector brackets underneath the gray cable.
  8. Gateway GWTC116-2BL Display Replacement: Schritt 8, Bild 1 von 2 Gateway GWTC116-2BL Display Replacement: Schritt 8, Bild 2 von 2
    • Remove the four 3.0 mm Phillips #00 screws located on the motherboard casing.
  9. Gateway GWTC116-2BL Display Replacement: Schritt 9, Bild 1 von 3 Gateway GWTC116-2BL Display Replacement: Schritt 9, Bild 2 von 3 Gateway GWTC116-2BL Display Replacement: Schritt 9, Bild 3 von 3
    • Peel the yellow tape off of the casing.
    • Lift the casing off of the motherboard.
  10. Gateway GWTC116-2BL Display Replacement: Schritt 10, Bild 1 von 2 Gateway GWTC116-2BL Display Replacement: Schritt 10, Bild 2 von 2
    • Peel off the yellow tape.
    • Remove four 3.0 mm Phillips #00 screws.
  11. Gateway GWTC116-2BL Display Replacement: Schritt 11, Bild 1 von 2 Gateway GWTC116-2BL Display Replacement: Schritt 11, Bild 2 von 2
    • Peel off the black piece of tape covering the display cable.
  12. Gateway GWTC116-2BL Display Replacement: Schritt 12, Bild 1 von 2 Gateway GWTC116-2BL Display Replacement: Schritt 12, Bild 2 von 2
    • Flick open the bracket securing the display cable and disconnect the cable from the motherboard.
  13. Gateway GWTC116-2BL Display Replacement: Schritt 13, Bild 1 von 1
    • Remove the motherboard from the device.
  14. Gateway GWTC116-2BL Display Replacement, Display: Schritt 14, Bild 1 von 1
    • Remove seven 3.0 mm Phillips #00 screws from the laptop.
  15. Gateway GWTC116-2BL Display Replacement: Schritt 15, Bild 1 von 1
    • Applying some force, use your hands to pry the display of the laptop away from the base.
Abschluss
Kailey Sousa
459 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team 6-2, Botvin Spring 2024 Mitglied von UMass Dartmouth, Team 6-2, Botvin Spring 2024
UMASSD-BOTVIN-S24S6G2
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 38
Insgesamt: 76
