Einleitung
If your Gateway GWTC116-2BL laptop is having problems with no power, no display, no sound, random crashes, or error messages, you may be experiencing a faulty motherboard. The motherboard is the main circuit board that connects and controls all the components of the computer. This can entail things like RAM and hard drive ports. Replacing a motherboard is simple, and below has step-by-step instructions to help you replace it in an orderly fashion.
Was du brauchst
Remove the ten 3.0 mm Phillips #00 screws from the back panel of the laptop.
Using your fingers, flick open the battery connector bracket.
Remove the connector from bracket.
Using your fingers, flick the cable connector bracket open.
Remove the cable from the connector.
Using your fingers, disconnect the black and white connector brackets underneath the gray cable.
Peel the yellow tape off of the casing.
Lift the casing off of the motherboard.
Flick open the bracket securing the display cable and disconnect the cable from the motherboard.
