Was du brauchst
Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
Locate the switch on the top left of the laptop labeled with a padlock symbol.
Flip the switch in the direction of the unlocked padlock symbol.
Use a metal spudger to pry off the DVD drive.
Once loosened, use your hand to pull the DVD drive out.
2 weitere Personen haben diese Anleitung absolviert.
