Zum Hauptinhalt wechseln
Gateway ID49C07U Screen Replacement
Was du brauchst
  1. Gateway ID49C07U Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the laptop over so the bottom of the device is facing upwards with the hinge facing away from you.
  2. Gateway ID49C07U Screen Replacement: Schritt 2, Bild 1 von 2 Gateway ID49C07U Screen Replacement: Schritt 2, Bild 2 von 2
    • Locate the switch on the top left of the laptop labeled with a padlock symbol.
    • Flip the switch in the direction of the unlocked padlock symbol.
  3. Gateway ID49C07U Screen Replacement: Schritt 3, Bild 1 von 1
    • Locate the switch that releases the battery and slide it to the right.
  4. Gateway ID49C07U Screen Replacement: Schritt 4, Bild 1 von 1
    • While holding the release switch to the right, pull the battery away from you.
  5. Gateway ID49C07U Screen Replacement, Screen: Schritt 5, Bild 1 von 1
    • Turn the laptop over and open.
  6. Gateway ID49C07U Screen Replacement: Schritt 6, Bild 1 von 2 Gateway ID49C07U Screen Replacement: Schritt 6, Bild 2 von 2
    • Use the Small metal spudger to remove the small black screw covers in the bottom corners of the screen
  7. Gateway ID49C07U Screen Replacement: Schritt 7, Bild 1 von 2 Gateway ID49C07U Screen Replacement: Schritt 7, Bild 2 von 2
    • Use the PH1 Screwdriver to remove the screws
  8. Gateway ID49C07U Screen Replacement: Schritt 8, Bild 1 von 1
    • Use the small metal spudger to start separating the front plastic cover from the back plastic cover
  9. Gateway ID49C07U Screen Replacement: Schritt 9, Bild 1 von 3 Gateway ID49C07U Screen Replacement: Schritt 9, Bild 2 von 3 Gateway ID49C07U Screen Replacement: Schritt 9, Bild 3 von 3
    • Once there is enough room for you to fit your hand underneath the top plastic cover you can start pealing it back. It will make a lot of popping noises as it unclips when you separate it.
  10. Gateway ID49C07U Screen Replacement: Schritt 10, Bild 1 von 3 Gateway ID49C07U Screen Replacement: Schritt 10, Bild 2 von 3 Gateway ID49C07U Screen Replacement: Schritt 10, Bild 3 von 3
    • Once the plastic cover is off locate the 4 screws in the corners of the screen and unscrew them
  11. Gateway ID49C07U Screen Replacement: Schritt 11, Bild 1 von 2 Gateway ID49C07U Screen Replacement: Schritt 11, Bild 2 von 2
    • After the screws are out gently flip the screen over onto the keyboard
  12. Gateway ID49C07U Screen Replacement: Schritt 12, Bild 1 von 1
    • Use the tweezers to peal back the tape over the wire connector on the bottom of the screen
  13. Gateway ID49C07U Screen Replacement: Schritt 13, Bild 1 von 2 Gateway ID49C07U Screen Replacement: Schritt 13, Bild 2 von 2
    • Hold the tape back with one hand and pull the connector out
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Ryan Howlett
267 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S6-G4, Isaacson Spring 2017 Mitglied von UMass Dartmouth, Team S6-G4, Isaacson Spring 2017
UMASSD-ISAACSON-S17S6G4
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 7
Insgesamt: 309
