Zum Hauptinhalt wechseln
Gateway KAV60 LT2016U Hard Drive Replacement
Was du brauchst
  1. Gateway KAV60 LT2016U Hard Drive Replacement, Battery: Schritt 1, Bild 1 von 3 Gateway KAV60 LT2016U Hard Drive Replacement, Battery: Schritt 1, Bild 2 von 3 Gateway KAV60 LT2016U Hard Drive Replacement, Battery: Schritt 1, Bild 3 von 3
    • Unlock the tab located in the top left corner of the netbook.
    • The red tab indicated that the battery has been properly unlocked.
    • Remove the battery.
    • When working with electronics, it is always wise to remove the power source before taking the device apart.
  2. Gateway KAV60 LT2016U Hard Drive Replacement, Hard Drive: Schritt 2, Bild 1 von 1
    • The hard drive is located under this cover.
  3. Gateway KAV60 LT2016U Hard Drive Replacement: Schritt 3, Bild 1 von 2 Gateway KAV60 LT2016U Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Remove the two (2) 5mm screws holding the cover down using the Phillips #0 screwdriver.
  4. Gateway KAV60 LT2016U Hard Drive Replacement: Schritt 4, Bild 1 von 2 Gateway KAV60 LT2016U Hard Drive Replacement: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to lift the cover.
  5. Gateway KAV60 LT2016U Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Using a Phillips #0 screwdriver, remove a third 5mm screw that holds the second cover that is directly protecting the hard drive.
  6. Gateway KAV60 LT2016U Hard Drive Replacement: Schritt 6, Bild 1 von 3 Gateway KAV60 LT2016U Hard Drive Replacement: Schritt 6, Bild 2 von 3 Gateway KAV60 LT2016U Hard Drive Replacement: Schritt 6, Bild 3 von 3
    • Slide the silver cover up; the hole on the cover and the hole for the screw will no longer match up.
    • Lift the silver cover; this will expose the hard drive.
Abschluss
Lydia Benjock
1.216 Reputation
10 Anleitungen geschrieben
Clemson, Team 14-3, Benson Fall 2013 Mitglied von Clemson, Team 14-3, Benson Fall 2013
CLEM-BENSON-F13S14G3
3 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 1,668
