Einleitung
Keys are very easy to replace with a plastic opening tool.
Was du brauchst
Unlock the tab located in the top left corner of the netbook.
The red tab indicated that the battery has been properly unlocked.
Remove the battery.
Any key on the keyboard can be replaced.
Insert the plastic opening tool under the key to be replaced.
The key is easily removed by applying force to the plastic opening tool until the key pops off.
Eine weitere Person hat diese Anleitung absolviert.
