Einleitung
The RAM can be replaced if you have a Phillips #0 screwdriver.
Was du brauchst
Unlock the tab located in the top left corner of the netbook.
The red tab indicated that the battery has been properly unlocked.
Remove the battery.
Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place.
Use a plastic opening tool to remove the cover.
Unlock the RAM by pinching the metal clamps that keep the RAM in place.
Remove the RAM while the metal clamps are disengaged.
