Ersatzteile
Kein Ersatzteil erforderlich.
Unlock the button in the top left on the back of the laptop (So the red is showing).
  • Unlock the button in the top left on the back of the laptop (So the red is showing).
Kommentar hinzufügen
The battery should be able to be removed easily now.
  • The battery should be able to be removed easily now.
  • The RAM is located under this cover.
  • Using a Phillips #0 screwdriver, remove one (1) 5mm screw holding the cover in place.
  • Use a plastic opening tool to remove the cover. Try opening tools of different sizes to find one that will easily open the cover.
  • Unlock the RAM by pinching the metal clamps that keep the RAM in place.
  • Remove the RAM while the metal clamps are disengaged. Use two opening tools, positioned on each side of the RAM, and push outwards to remove the RAM.
Abschluss
Emily
Mitglied seit 11.03.2014
301 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 3-2, Calaway Spring 2014 Mitglied von UMass Dartmouth, Team 3-2, Calaway Spring 2014
UMASSD-CALAWAY-S14S3G2
4 Mitglieder
18 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 113
