Einleitung
This guide demonstrates how to safely remove and replace the RAM stick of a Gateway LT2104u.
Was du brauchst
Locate the the "L" shaped cover on the back, lower right hand side the device. Using a Philips screwdriver, remove the screw holding it in.
Gently push the levers on each side of the stick of RAM away from each other until the RAM springs into a 45° angle.
Carefully remove the stick of RAM by pulling at the same 45° angle the RAM is currently at until it detaches from the device.
Eine weitere Person hat diese Anleitung absolviert.
