Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
In any computer repair, removing the power source will prevent many dangerous situations. It should be the first thing you do whenever you want to make any repair or replacement.
  1. Place the laptop upside down on a flat surface so you can see the battery.
    • Place the laptop upside down on a flat surface so you can see the battery.
  2. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  3. Pull the two marked tabs towards the outside of the computer to unlock them.
    • Pull the two marked tabs towards the outside of the computer to unlock them.
  4. While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
    • While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
Abschluss
To put the battery back, just slide it back into its slot and make sure that both locking tabs are locked.
Michael Smith
401 Reputation
4 Anleitungen geschrieben
UMass Dartmouth, Team S66-G8, Rockett Fall 2017 Mitglied von UMass Dartmouth, Team S66-G8, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G8
3 Mitglieder
12 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 3
Insgesamt: 98
