Einleitung
This is the guide for complete removal of the Gateway LT41P10u monitor. When removing monitor handle with care to avoid possibly cracking the screen.
Was du brauchst
Place the laptop upside down on a flat surface so you can see the battery.
While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
Carefully use a spudger to separate the monitor from top panel.
Gently remove lower hooks from the hinges. (see second image)
Once you completed separating the monitor from the top panel disconnect the cable shown here in red by raising the cable lock and pulling the wires away.
The second image is how it should look once completely disconnected.
To reinstall your device, follow these instructions in reverse order.
