Zum Hauptinhalt wechseln
Gateway LT41P10u Webcam Replacement
Was du brauchst
  1. Gateway LT41P10u Webcam Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place the laptop upside down on a flat surface so you can see the battery.
  2. Gateway LT41P10u Webcam Replacement: Schritt 2, Bild 1 von 1
    • Pull the two marked tabs towards the outside of the computer to unlock them.
  3. Gateway LT41P10u Webcam Replacement: Schritt 3, Bild 1 von 1
    • While keeping both of the tabs in the unlocked position, grab the battery and pull outwards, until the battery slides out from the rest of the computer.
  4. Gateway LT41P10u Webcam Replacement, Monitor: Schritt 4, Bild 1 von 2 Gateway LT41P10u Webcam Replacement, Monitor: Schritt 4, Bild 2 von 2
    • Carefully use a spudger to separate the monitor from top panel.
    • Gently remove lower hooks from the hinges. (see second image)
  5. Gateway LT41P10u Webcam Replacement: Schritt 5, Bild 1 von 2 Gateway LT41P10u Webcam Replacement: Schritt 5, Bild 2 von 2
    • Once you completed separating the monitor from the top panel disconnect the cable shown here in red by raising the cable lock and pulling the wires away.
    • The second image is how it should look once completely disconnected.
  6. Gateway LT41P10u Webcam Replacement, Webcam: Schritt 6, Bild 1 von 1
    • Using a plastic spudger or fingers gently remove webcam hardware from front screen. A gentle heat source can be used to easily remove glued down parts.
    • Once webcam hardware is removed from front screen, it can be removed by hand from the wiring and replaced.
    • Perform these steps carefully as smaller parts are more likely to break.
Abschluss
Patrick Raposo
201 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S66-G8, Rockett Fall 2017 Mitglied von UMass Dartmouth, Team S66-G8, Rockett Fall 2017
UMASSD-ROCKETT-F17S66G8
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 130
