Einleitung
If your computer is failing due to old age and you think you need a CPU replacement, follow this guide to help replace it.
Was du brauchst
Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
Once the fan is removed, locate the CPU.
Rotate the plastic knob using a flat head screw driver as depicted in this image
