Zum Hauptinhalt wechseln
Einleitung
The replacement of the hard drive may be necessary if you experience crashes frequently or if there is data loss and file corruption. You can also upgrade the hard drive if you would like to have access to more storage or faster laptop in general, either way, try out this simple guide!
Ersatzteile
Keine Ersatzteile angegeben.
  1. To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • To prevent injury, make sure the laptop is not plugged in while removing the battery!
    • Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
  2. Push the switch to the right, toward the inside of the computer to dislodge the battery. Finally, pull the battery outwards and away from the laptop as depicted in this image. Finally, pull the battery outwards and away from the laptop as depicted in this image.
    • Push the switch to the right, toward the inside of the computer to dislodge the battery.
    • Finally, pull the battery outwards and away from the laptop as depicted in this image.
  3. Using the Phillips #1 screwdriver, remove the three 6mm screws holding the hard drive panel in place. Using the Phillips #1 screwdriver, remove the three 6mm screws holding the hard drive panel in place.
    • Using the Phillips #1 screwdriver, remove the three 6mm screws holding the hard drive panel in place.
  4. Using the plastic opening tool, pry open the plastic panel covering the hard drive.
    • Using the plastic opening tool, pry open the plastic panel covering the hard drive.
  5. Using your hands, carefully pull out the hard drive from its compartment. Using your hands, carefully pull out the hard drive from its compartment. Using your hands, carefully pull out the hard drive from its compartment.
    • Using your hands, carefully pull out the hard drive from its compartment.
Abschluss
Femi
198 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team S3-G7, Peak Fall 2018 Mitglied von UMass Dartmouth, Team S3-G7, Peak Fall 2018
UMASSD-PEAK-F18S3G7
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 2
Insgesamt: 83
