Einleitung
If your laptop keeps crashing or is running slow, then consider replacing the RAM of your device using this guide here.
Was du brauchst
Make the switch in the upper right corner of the turned over laptop is switched to the "unlocked" position. (the unlocked padlock icon)
Push the switch to the right, toward the inside of the computer to dislodge the battery.
Finally, pull the battery outwards and away from the laptop as depicted in this image.
Using the Phillips #1 screwdriver, remove the four 6mm screws on the back of the laptop.
Insert the plastic prying tool and pry the back panel off starting at an edge and moving your way around it.
